Ga door naar hoofdinhoud
The ASUS Transformer Book Flip TP500LA is a 2-in-1 laptop with a 15.6-inch screen and a 360-degree display.
15 Vragen Bekijk alle
Why is my laptop overheating after only a few minutes of use?
My ASUS Transformer Book Flip TP500LA has been overheating way too quickly recently and that has me worried it may cause damage to it if this keeps up. I'm not sure what's wrong, although I suspect that it may be that the fan is not working but I'm not sure how to get to the fan. Is there a way I can access the fan in order to possibly replace it?
Is dit een goede vraag?
Score 1
2 opmerkingen
Why is my laptop time and date not correct, I do correct everytime I switch on the laptop?
door
@olatokunbo84505
Please confirm the make and model number of your laptop?
door
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
Overuse may be contributing to your fan overheating too quickly. Aside from simply lessening use, it might by better to shut it down completely, rather than just putting it into sleep or hibernate mode. As for getting to the fan and attempting to replace it, you would be aiming to remove the bottom cover of the computer base. The fans are generally placed on the back of the computer behind the keyboard and under where the top screen is. If your fan is heating up the base of the computer too much, your motherboard or other crucial parts and functions can be damaged, as well as damaging whatever surface your computer is being used on (especially your skin). After that, it's just a matter of getting the right part for your computer, and that can be found in parts shops and online in places such as eBay or the Asus official website.
Was dit antwoord nuttig?
Score 2
I have experienced this very same thing due to build up of dust, dog hairs etc.
Have you tried to use a vacuum cleaner and suck gently where the fan is located?
It has worked wonders for me on more than 2 instances where I thought my computer was sick. Good luck.
Score 1
Use this IFIXIT guide on how to open your computer and clean the fans.
Click here.
You could also possibly upgrade your RAM and SSD drive while you are there.
Voeg je antwoord toe
Willie Contreras Gabriel zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 1,991
