Ga door naar hoofdinhoud
ASUS Transformer Book Flip TP500LA Fan Replacement
Wat je nodig hebt
  1. ASUS Transformer Book Flip TP500LA Fan Replacement, Back Case: stap 1, afbeelding 1 van 3 ASUS Transformer Book Flip TP500LA Fan Replacement, Back Case: stap 1, afbeelding 2 van 3 ASUS Transformer Book Flip TP500LA Fan Replacement, Back Case: stap 1, afbeelding 3 van 3
    • Remove the ten 10 mm Phillips #0 screws found on the computer's back case.
    Vraag FixBot
    Voeg opmerking toe
  2. ASUS Transformer Book Flip TP500LA Fan Replacement: stap 2, afbeelding 1 van 2 ASUS Transformer Book Flip TP500LA Fan Replacement: stap 2, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Heavy-Duty Spudger
    • Slide a heavy-duty spudger between the back case and the computer.
    • Slowly work around the edges to undo the clips to fully separate the back case from the computer.
    • Gently lift off the back case.
    Vraag FixBot
    Voeg opmerking toe
  3. ASUS Transformer Book Flip TP500LA Fan Replacement, Battery: stap 3, afbeelding 1 van 2 ASUS Transformer Book Flip TP500LA Fan Replacement, Battery: stap 3, afbeelding 2 van 2
    Heavy-Duty Spudger
    • Slide a heavy-duty spudger into the ZIF connector and gently flip up the retaining flap to open the connector.
    • Pull the blue tab to remove the ribbon.
    Vraag FixBot
    Voeg opmerking toe
  4. ASUS Transformer Book Flip TP500LA Fan Replacement: stap 4, afbeelding 1 van 2 ASUS Transformer Book Flip TP500LA Fan Replacement: stap 4, afbeelding 2 van 2
    • Remove the three 5 mm Phillips #0 screws.
    • Remove the single 6 mm Phillips #0 screw.
    Vraag FixBot
    Voeg opmerking toe
  5. ASUS Transformer Book Flip TP500LA Fan Replacement: stap 5, afbeelding 1 van 2 ASUS Transformer Book Flip TP500LA Fan Replacement: stap 5, afbeelding 2 van 2
    • Use the heavy-duty spudger to pry the white 8-pin connector away from the motherboard.
    • Gently pull the connector away from the motherboard.
    • The black 8-pin connector on the motherboard is very fragile, so be careful when removing the white 8-pin connector.
    Vraag FixBot
    Voeg opmerking toe
  6. ASUS Transformer Book Flip TP500LA Fan Replacement: stap 6, afbeelding 1 van 2 ASUS Transformer Book Flip TP500LA Fan Replacement: stap 6, afbeelding 2 van 2
    • Use the blue plastic opening tool to loosen and remove the three black wires from the battery.
    • Slide the battery out from the computer to remove.
    Vraag FixBot
    Voeg opmerking toe
  7. ASUS Transformer Book Flip TP500LA Fan Replacement, Fan: stap 7, afbeelding 1 van 2 ASUS Transformer Book Flip TP500LA Fan Replacement, Fan: stap 7, afbeelding 2 van 2
    • Unscrew the six 5 mm Phillips #0 screws.
    Vraag FixBot
    Voeg opmerking toe
  8. ASUS Transformer Book Flip TP500LA Fan Replacement: stap 8, afbeelding 1 van 3 ASUS Transformer Book Flip TP500LA Fan Replacement: stap 8, afbeelding 2 van 3 ASUS Transformer Book Flip TP500LA Fan Replacement: stap 8, afbeelding 3 van 3
    • Grasp the top of the 3-pin connector with tweezers.
    • Wiggle the connector until it loosens itself from the motherboard.
    • Gently lift the connector from the motherboard attachment.
    Vraag FixBot
    Voeg opmerking toe
  9. ASUS Transformer Book Flip TP500LA Fan Replacement: stap 9, afbeelding 1 van 1
    • Carefully lift the fan off the motherboard.
    • Attached to the fan is thermal pasting that needs to be reapplied when attaching the fan back to the motherboard. Follow this guide to reapply thermal pasting correctly.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
Solomon Dovinh
435 Reputatie
2 handleidingen geschreven
Cal Poly, Team S13-G5, Forte Spring 2017 Lid van Cal Poly, Team S13-G5, Forte Spring 2017
CPSU-FORTE-S17S13G5
3 Leden
6 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 19
Altijd: 2,279
