Ga door naar hoofdinhoud
A touchscreen smartphone made by LG released in September 2013 with the model number VS980.
Water damage, how to fix without schematic?
So I got a lg g2 with water damage for 16 bucks. It's a T-Mobile and it also has a bad charge port. Problem is I don't have a schematic. If I clean it with isopropyl and it still does not work, what could I do? Do lg schematics even exist?
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
@gigabit87898 it can be done but makes for a tough job. Yes they do but never search for something like "LG G2" use the model number instead. You should find something like this
Was dit antwoord nuttig?
Score 4
4 opmerkingen:
I found a service manual for a D803 but this is a D801. Would it be the same pcb layout?
door
@gigabit87898 that is where you have to check the board layout in the SM against the actual board. D801 is a t-Mobile and D-803 is the Canadian Version. It may essentially be the same.
door
So I fixed this phone, everything works. But, it had custom recovery, rom and bootlogo. How do I reset everything to factory including the recovery?
door
Fixed it, typing this on it right now.
door
Voeg je antwoord toe
Gigabit87898 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 153
