Ga door naar hoofdinhoud
A cordless electric razor manufactured by Philips in 2006.
What if the batteries are worn-out?
What if the batteries are worn-out? It might be a simple replacement process; I have this problem also, but I don't know how to remove the back cover TO replace the batteries...
Is dit een goede vraag?
Score 1
1 Opmerking
How do you replace the battery in the Philips Norelco 7110X
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
@landanm , @scottdeutsch , Scott D. Deutsch, Some devices do not power on when charging, I am not sure if that is the case for this shaver or not, to answer @landanm inquiry. If you have a Philips Norelco 5801XL find below a guide to battery replacement. This will also give you a chance to look at other components/wires that could be loose/damaged/burnt. I suggest you first try another compatible charger or have charger tested and also if able clean the charge port of any dust/lint carefully with tooth pick or blow out with canned compressed air. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Philips Norelco 5801XL Battery Replacement
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Scott D. Deutsch zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 8
Altijd: 791
