Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De Dyson AM07 is een bladloze torenventilator die in 2014 op de markt kwam. De AM07 maakt gebruik van "Air Multiplier"-technologie om een gelijkmatige luchtstroom te creëren zonder zichtbare bladen.
fan not oscillating back and forth
What's wrong and how do I fix it?
Is dit een goede vraag?
Score 1
1 Opmerking
I have the problem too, it is not oscillating.
door
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Gekozen oplossing
mkoch, If it is new, did you remove the tape, from the lower base body split section, if not remove before turning on any more or damage to internal gear could occur. Recheck that the fan is still assembled correctly and locked in correct position. Install new batteries in remote and try. If all looks good and still under warranty return for repair/replacement/refund as there may internal damage to oscillating gear. See below links, your manual and Dyson support site.
Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.manualslib.com/manual/888752...
https://www.dyson.com/support/am02/am02-...
Was dit antwoord nuttig?
Score 7
2 opmerkingen:
So simple, duh, I forgot the tape. But it doesn’t show that in the setup instructions.
door
I need help in opening the remote. I've had three people look @ this remote. Pls help!!!!!!!!!!!!
door
It would be more helpful if the tape that has to be removed was an obviously different colour rather than white the same as the oscilating plinth - ie ... make it idiot proof - it took me a while to work it out as well lol
Voeg je antwoord toe
mkoch zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 89
Altijd: 51,072
