Ga door naar hoofdinhoud
This digital camera was announced by Panasonic in January 2014. The Panasonic Lumix DMC-ZS40 has a 18 megapixel sensor and built-in GPS features.
8 Vragen Bekijk alle
Why is LCD screen having color changes?
The LCD screen will become filled with blue/green colors. This does not happen with every photo but I am concerned it will get worse. The colors do not affect the photo but makes it difficult to see the screen. Does anyone have experience with this problem?
I've not been able to do any troubleshooting as the owner's manual does not address this problem.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
@silverjym since this does not affect the images it could be a failed/failing LCD. Here are the instruction on how to change it:
Should this not fix it, you are most likely having issues with the LCD driver on the circuit board. For now go with the LCD.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Jeannine Roman zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 1,332
