Suggested troubleshooting procedure:
1.- Go to settings > Check your firmware version.
2.- If 4.1 or higher your flashcard could be not compatible (R4s, etc)
3.- Check with an original game
4.- If still not recognized open your DS
5.- Look for continuty in the Slot-1 pins and as well in the swtich that check if the game is inside (are the two contacts solder aside of the slot-1)
6.- If not having continuty or a bended pin your solution will be to desolder the slot-1 and replace with a new one.
Manuel / Montreal
Console Fix Parts
5 opmerkingen
when i go onto my game it just says menu with a questions mark and its been working fine all this time but i dont know about now
door aman
Maybe they are just dirty try to blow in the slot if not blow on the game and if that doesn't work then you might want to get it looked at that happened to my friend too
door Samara
hi I have a dsi when I put a game in then turn it on it does not see the game. can you fix it for me.
door kellyjackson87
Whe never I insert my game card into my dsi xl's game card slot it won't read it no matter what, I've tried blowing into the game card slot,and I've paratcly tried every thing to make it work but it won't does that mean that the game card slot is broken and needs to be repaired?
door Naomi Morrison
@Naomi Morrison well the only solution is to replace the slot.
door dudewiththe101
