Ga door naar hoofdinhoud
Vraag afgerond
Not boot up. Just the led for a few seconds.
The macbook, does not boot. No start up chime.
When the power button is pressed, the light comes up for a 2 seconds, a little click near the hard drive then the lights off. The battery is ok, charging is ok. I've reseted the SMC.
Is dit een goede vraag?
1 Opmerking
There is no 17" A1260, please give us the last three letters of your serial number
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
It was a damaged LogicBoard
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
Really, according to whom? The most expensive thing it could be. You didn't give us much of a chance to help or help us help you. You might consider trying again.
door
According to my tests. My question was posted on December 29, 2010, and nobody gave me a little comment. 3 months is a long time if you or someone wanted to bring some help.
door
Easy folks, it has only been 1 1/2 month since you posted your question. You did not respond to the request for your serial number from the same day. Please remember that everyone on here answers questions voluntarily and tries to do their best. Good Luck
door
Sounds liek the hard drive bit the dust, try holding option when booting, and see if it give you a choice of drives to boot from
1 Opmerking:
I tested all components before: Hard Disk, Ram, airport, Fan, etc. that is why I say it is the logicboard. also is not the only case, since I saw two macbook air and a macbook with the same symptoms and all those had a bad logicboard.
door
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 989
