Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Vragen Bekijk alle
iPhone 5S dead after U2 ic replacement.
I have an iPhone 5s that battery was draining very fast, this happened after using cheap iPhone chargers. I decided to replace the U2 ic, after job done, phone started, booted to IOS and worked fine. I tried to charge this and when I put cable on the phone the screen got black and phone went completely dead. I replace the U2 chip again and no sigh of life. Can someone help me, why is this happened? Why is this worked only for some minutes? I burn any resistor? What parts need to test to find the problem? Thank you!
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Did you actually check battery health using 3utools or coconut battery?
Was dit antwoord nuttig?
Score 1
1 Opmerking:
battery is fine
door
Het nuttigste antwoord
Try replacing the Q2 IC (4 PIN IC), right above it. You can harvest a good one from an old board, if you have one.
Score 2
1 Opmerking:
Ι don't have an old motherboard, I will order a new IC and I will come back with the result.
door
Voeg je antwoord toe
johnfl21 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 1,183
