Ga door naar hoofdinhoud
Released October 24, 2011 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
405 Vragen Bekijk alle
Strange blue lines on my MacBook
Hi,
My MacBook Pro was having problems. Apple reseller diagnosed a broken logic board €1000. I went to an other store and they replaced the video card.
The mac is working but now I'm having this strange issue (this problem started before the mac was fixed)
I'm having blue lines (see pictures)
in different websites (not always, sometimes I can work for hours without any problem) the only thing I can do when this happens is power off the mac with the power button.
Is this a software problem or is there still a hardware problem.
Update (04/06/2017)
On the invoice is noted VGA repair. So not sure it was the graphics card that is changed
Is dit een goede vraag?
1 Opmerking
Was it repaired under the program?
MacBook Pro Repair Extension Program for Video Issues
https://www.apple.com/support/macbookpro...
When was it6repaired?
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
That looks like the mouse is "selecting" text on the screen, does this only happen on web pages?
Was dit antwoord nuttig?
Score 3
6 opmerkingen:
Good Point! I didn't magnify the image (my bad)
That's it! The selection action is engaged. So he has a trackpad problem where the click plate is not correctly set or the ribbon cable is not seated. Or, lastly there was some liquid damage on the trackpad logic.
door
I would remove the trackpad ultrasonically clean it and inspect the ribbon cable and replace if necessary.
door
Okay, but why is the screen stuck when this happens. I need to power down the mac with the power button.
door
If it is in a state of constant "selection" it could be locking up the Mac, just a thought
door
@idoc open this up, disconnect the trackpad, then try and use it with a USB mouse. If you are no longer experiencing this issue, it will be related to the trackpad.
door
1 commentaar meer tonen
Voeg je antwoord toe
Mattis zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 897
