Ga door naar hoofdinhoud
De Xbox draadloze controller 7MN-0001, vervaardigd door Microsoft Corporation, is de meest gebruikte controller voor Xbox-spelcomputers en kan ook in combinatie met pc's worden gebruikt.
Broke LT and RT holders how do I replace it?
Afbeelding
Afbeelding
I have provided two pictures, the blue controller is the one that I'm trying to fix. The dissasembled controller is the one I'm using for the RT and LT.
I want to remove the Trigger holder from the controller but don't know how to do it.
It's the metal piece holding the Triggers.
I need help guys.
Is dit een goede vraag?
Score 3
1 Opmerking
Hello, my RT button on my Xbox One controller is not working correctly. When I get on NFS the car drives by its self.
door
Voeg een opmerking toe
6 Antwoorden
Het nuttigste antwoord
https://www.youtube.com/watch?v=NZp8Rcik...
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Thanks for that
door
Hello @imzai,
There is no photos as I can see, did they upload correctly?
Well, I provided a few IFixIt links that may help
Vervanging van de trilmotoren in de triggers van de Xbox One draadloze controller
Xbox One draadloze controller-knoppen vervangen
I hope these help!
Thanks,
Keegan
Xbox One Wireless Controller Model 1537 Trilmotoren van de triggers Afbeelding
Handleiding
Moeilijkheid:
Moeilijk
15 - 20 minutes
Xbox One Wireless Controller Model 1537 Knoppen Afbeelding
Handleiding
Moeilijkheid:
Moeilijk
30 minutes - 1 hour
Score 1
3 opmerkingen:
I have edited my post, I've uploaded the pictures, what I mean to to remove from dissasembled controller is the metal stick holding the triggers.
door
Okay I see, so if you look back in to the link Vervanging van de trilmotoren in de triggers van de Xbox One draadloze controller it shows how to remove the moters. So, I think by the look of the photos its soldered to the board. Can you confirm this?
door
You have to press the small part of the metall pin then it comes out on the other side where you can grab it with pliers / tongs / nippers and pull it out gently.
You have to be very carefull, else you destroy the trigger or the frame.
I need a LT trigger spring
Afbeelding
How to take this off lt button
1 Opmerking:
Same here, my rigger holder is broken too
door
My left triggers has came out of the socket please help
Voeg je antwoord toe
J Angel zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 54
Altijd: 30,994
