Ga door naar hoofdinhoud
MacBook will not boot but will charge
I few days ago my macbook stopped turning on. When I hit the power button I get absolutely no response. Nothing from the LEDs, no fans, the harddrive does nothing in short the thing is completely unresponsive. The odd thing about this is that the battery is fine and the charger light comes on. I'm hoping it's just the power button, in which case I could just replace the upper case. Is there a way to test this? Could I remove the upper case and short the thing on? Or does this sound like a logic board issue? Thanks in advance.
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I found this pic for you, hope it helps:
Won't power on even after replacing logic board.
Was dit antwoord nuttig?
Score 3
1 Opmerking:
Thank you! It took my a while to get a #000 Philips but that was exactly what I was looking for.
door
Voeg je antwoord toe
Areaman zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 5
Altijd: 1,479
