Ga door naar hoofdinhoud
Repair guides and support for HP's LaserJet Laser Printer Line, which includes printers with model numbers starting with LaserJet, LaserJet Pro, Color LaserJet, P, M, CP, and CM.
20 Vragen Bekijk alle
HP P1005 LaserJet printing with streaks on paper, Cleaning?
This printer was relatively inexpensive and is great for documents in Black & White. Quick, efficient and cheap to operate.
How do I disassemble it to clean the mechanics to get a cleaner printout ?
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
You could try to clean the print-cartridge area as well as to clean the device paper path if you are experiencing toner specks or dots on the printouts. you might also try to clean the pickup roller. the users manual describes all those steps in detail and is available at http://www.retrevo.com/samples/HP-Printe... as well as http://h10025.www1.hp.com/ewfrf/wc/manua... Good Luck
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Dead links live links are needed to access user manuals.
door
Hi @ dave.trotsky.ireland
Here's a link to the User manual for the P1000 series printer taken from this webpage
door
Voeg je antwoord toe
capone99 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 9
Altijd: 6,506
