Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
High performance tablet computer released by Apple on November 11, 2015. Model A1584.
86 Vragen Bekijk alle
Is it possible to put a 12MP Camera in the 12" iPad Pro?
I was wondering if you were able to open the iPad up and use the 12MP camera in the 12" iPad? I mean theres only a few differences between the 9" and the 12" iPad Pro's and the camera is a major one so I was wondering if I were to buy a 9" replacement 12MP camera and install it in the 12" iPad Pro, would it work? Could I then record 4K, etc?
Update (03/23/2017)
Thanks guys. I guess I'm stuck with the iPad Pro with a crappy camera. I mean I don't really take a lot of pics with the iPad anyhow. It's good enough to scan docs with. I just thought it would be cool.
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Commentaar:
It probably isn't a good idea to swap hardware from device to device. The current draw/supply voltage may be different, or the iPad may not be able to understand the information that the camera encodes and sends over the PCB
door
Voeg een opmerking toe
LCD iPhone-scherm fixkits
De goedkope optie, ondersteund door onze levenslange garantie.
Koop kits
Bespaar op reparatiekosten, niet op kwaliteit.
Koop kits
2 Antwoorden
Gekozen oplossing
I think its too risky to even try. Opening up the iPads is not easy! Besides, the rummer-mill is ripe with hints Apple will be dropping a refresh of the Pro series soon. I would hold off until then.
Was dit antwoord nuttig?
Score 2
Het nuttigste antwoord
Unfortunately, the connectors are different. Also, the iOS is specifically calibrated specifically included camera. If you were able to get a camera from a model to register, I don't think the camera would work properly.
Score 2
Voeg je antwoord toe
Jeff Dodge zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 97
