Ga door naar hoofdinhoud
Een breed scala aan reparatiehandleidingen en ondersteuning voor de consumentenlaptoplijn van Toshiba.
no audio output device is installed
no audio output device is installed ive tried in install from control panel and gone to install drivers but keep ketting an error
Is dit een goede vraag?
Score 21
3 opmerkingen
Hi,. My audio is uninstalled and I have the conexant but I can't figure out how to get it on the laptop
door
tidak ada suara keluar dari laptopsaya
door
ihavevthisvprroblem on my laptop almost for three month until now i cant fix it
door
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
There are several ways to fix the no audio output device is installed problem. I have shared them below, so follow those techniques to get the solution.
  1. Please assure that the device is not disabled from windows settings or bios.
  2. Update the audio software on your computer. may be the device is running on outdated software, that’s why it can’t play the audio.
  3. Reset the audio driver on your computer too, If there is any driver running out
  4. Check the speakers, insert the headphone into the pc. now check the computer.
  5. Reset the computer if necessary.
After making the changes, you will get the audio on your device.
Was dit antwoord nuttig?
Score 2
What version operating system are you using? What is the exact error message you get when you install the drivers?
Some things to try:
Right click on the speaker symbol on the task bar and click on "Playback Devices" to see if the audio output is set for what you use.
Go into BIOS and check that the audio is enabled.
Check Control Panel - Device Manager and see if there is a yellow mark next to the audio device. You can try removing the Audio device and also remove the drivers, click on "Action" and select "Scan for Hardware Changes" and let Windows find and configure the audio driver.
Score 1
3 opmerkingen:
It says it's not installed n when I try to install it, it errors. It's a Toshiba satellite c655 laptop
door
Also, where is bios located?
door
To access the BIOS, turn on the computer, press F2 key when the Toshiba screen shows. BIOS is the hardware level also called Firmware. What you are looking for is Audio and check to see that it is enabled.
door
Ive tried to fix the audio out put but to no avail plz help me out
Voeg je antwoord toe
louloublue40 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 30
Altijd: 11,065
