Massey Ferguson tractor won't start
My tractor won't stay running without easy start, it ran low on fuel have tried to get air out but still won't run, it will turn over but that's it, can anyone help me please.
Is dit een goede vraag?
@holly1catherine ,Catherine, Ensure battery is fully charged. Trouble bleeding air out, just barely crack open each fuel line (one at a time) right at the injector while someone cranks the engine over. As soon as you get fuel coming out tighten it back up again. If no fuel could be plugged filter, clogged/damaged/pinched fuel line, faulty pump. The link below has a really thorough write up on bleeding/trouble shooting diesel fuel system approx 1/2 way down the page. Good luck.
Was dit antwoord nuttig?
hello, i had the same problem with my 1100 massey ferguson. was down and i went thru the entire fuel system. but when i was trying to crank it, the engine did the same thing. it was down for three years with no luck running. i finaly was going thru everything and thats when i removed both filters and noticed that one of my wix filters did't have holes on top like the other one. so just to be sure, i purchased two new filters of a didderent brand and both had holes on the top and after bleeding the system, the engine cranked. check your filters and goodluck.
check our neual safty switch ires mine was loose
You are welcome you have a salty switch under the seat
Sorry about spelling that is saftety
I have a Ferguson t20 tractor I put a new carburetor on it I have crank no start I put a new fuel on, had starting fluid sprayed in carburetor starter right up two seconds turned off what am I doing wrong.
( JOHN P )
I got a 1977 Massey Ferguson tractor charge the battery up ram shut it off won't start what do I do
What do I do to get it started
I charge the battery till it gets full and it starts then after I shut it off it won't start again what do I do
I have an 1957 mf20 it’ll start with starting fluid but then it’ll stop I’ve checked the fuel line they are all good the fuel pump is good what is wrong???
Afgelopen 24 uren: 16
Afgelopen 7 dagen: 118
Afgelopen 30 dagen: 406
Altijd: 30,038
2 opmerkingen
my MF 202 will not start It stalled . I turn the key on push start button nothing happens
door johnrdv
Having trouble starting a Massey Ferguson tractor? Frequently ask a question on Google by Farmers. Make sure the battery is fully charged. If you are having trouble bleeding out air, just barely open each fuel line (one at a time) while someone cranks the engine. Once fuel starts coming out, tighten it up again. https://www.tractorcorner.com/jm/
door tractorcorner
