How can I fix it?
MY calculator won't turn off except after being left alone for a long period of time and the buttons aren't responding. Also it only displays 0=. and I've even tried restarting it many times.
Is dit een goede vraag?
Hi,
Try replacing the battery and then resetting the calculator.
The EL-531X uses a LR-44 (or equivalent) battery
Here are two images that show what to do.
Battery Replacement
Reset
(click on images to enlarge for better viewing)
Was dit antwoord nuttig?
Hi. After changing battery and resetting, all the buttons still didn't work. Please help.
I had the same problem and managed to fix it by removing the battery and unscrewing and removing the back cover. That's it. I reckon that the issue happened because the "=" key connection was stuck, so uncovering the calculator might have "released" the connection. Hope this helps!
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 43
Altijd: 5,352
1 Opmerking
The calculator will display 1 no matter with the battery or not.
It stop working.
door Wen Qiu Deel
