Ga door naar hoofdinhoud
Blue, red or white 11" Dell Inspiron 11-3162 released on February 16, 2016.
13 Vragen Bekijk alle
How many hours am I going to charge this?
I don't know the charging hours for this.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi,
Check the battery status icon on the taskbar. It should give an indication of the remaining charge time.
The time it takes to charge depends on how low the battery was when you first started to charge the battery and also whether the laptop is on at the time and if you are using it as well, which means that it will take longer than if it was switched off and it was just charging.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Christine Judith Ducusin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 153
