Headlights blinking bright to dim
Headligets blinking bright to dim
Is dit een goede vraag?
christinezaf if the brightness of your headlights pulsates from bright to dim and back to bright have your alternator, battery and wiring checked. Sometimes bad brushes as well as corroded wiring can be the cause of that.
Was dit antwoord nuttig?
Going to try changing negative battery terminal connector it is corroded will let you know if that fixes headlight malfunction
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 62
