Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Reparatie-informatie voor de Garmin Vivoactive HR smartwatch. Uitgebracht in februari 2016. Modelnummer: 010-01605-03.
display broken / need replacement display
Hey everyone,
unfortunatly I crashed the display of my Gamin Vivoactive HR.
I called Garmin for a replacement and they told me its about 150€.
Is there any other possibility to replace the display by my own?
Buy the display seperatly anywhere ?
I am thankful for every help
Best regards,
Andreas
Is dit een goede vraag?
Score 5
1 Opmerking
Hey everyone,
Best regards,
Cesare
door Deel
Voeg een opmerking toe
5 Antwoorden
Filteren op:
Het nuttigste antwoord
Hi Andreas,
I have a used display. Are you still interrested?
Was dit antwoord nuttig?
Score 2
7 opmerkingen:
Is the used display still available?
door Deel
Yes is still available
door Deel
Hey there, I am also interrested. Could you please tell me if the Display is still available? You can also directly contact me via gerrit.puddig "@" conjin.de. thanks
door Deel
Hi.
May I know ifthe display still available?
door Deel
Leonidos didn't answer me. See my Question above...
door Deel
2 commentaren meer tonen
I had to open my Vivoactive HR because it wad died, what I saw it was water inside device :(
Now I know that it is no super easy way to open this Garmin.
1st. you have to unglued plastic part where buttons sits
2nd. using this hole (buttons whole) you should gently push screen using something like screw
  • be careful with electric tapes (there are few) it is easy to broken (tear) using only a little force
  • there is only 1 screw on button board
Maybe my photos will help anybody to repair this Garmin.
Afbeelding
Afbeelding
Afbeelding
Afbeelding
Afbeelding
Afbeelding
Afbeelding
Afbeelding
Afbeelding
Afbeelding
Score 1
Afbeelding
Afbeelding
So I have a vivoactive hr and yes a crack screen n unresponsive to touch too. Opened it up( direct from screen) and it wasn’t that hard too, but I really hope they start selling the screen so maybe one day I can replace it.
2 opmerkingen:
How did you get the screen off? Trying to get it off without completely destroying the unit.
door Deel
It’s being hold down by adhesive tape so use heat
door Deel
You can buy a display there :
https://www.smitacn.com/lcd-screen-for-g...
Good to know for future, but in not much more you can buy used but working device :)
Voeg je antwoord toe
Andreas zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 55
Altijd: 5,269
