Ga door naar hoofdinhoud
Reparatie-informatie voor de uitrusting die je gebruikt om eropuit te trekken en actief te blijven.
My treadmill won't turn
TREADMILL NEW BALANCE
1500 TREADMILL
Treadmill turns on, It is locked in
12% incline, belt does not move, have
tried all controls. No response.
Is dit een goede vraag?
Score 1
2 opmerkingen
This question was migrated from http://meta.ifixit.com/.
door
Pat Gross, just wondering if you ever got your treadmill fixed.
door
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
Pat Gross, do you have an err 3 code on the screen. Sometimes the treadmill will loose its incline signal. You may have to reset this by removing and then replacing the Safety Key. If that does not work I would think that there are the possibility of
a: mechanical failure. Remove the bottom cover and see if all the mechanisms are in place and nothing binds with the deck or
b: problems with the PCB in your control. Which would probably need to be replaced. Sorry can't be more specific with this. Good luck
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Anyone else can help out?
door
Voeg je antwoord toe
Pat Gross zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 24
Altijd: 2,019
