Ga door naar hoofdinhoud
Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Vragen Bekijk alle
iPhone 5 shutting down
So alike to my 5s, my iphone 5 is having the exact same problem (batt died, didn't change it till about halve a year later), its shutting down by itself when not in use, what's different is that there are lots of panic code in the diagnostic.
Problem:
Phone keeps shutting down when not in use, changing battery doesn't solve the problem.
Question:
Which IC is broken? Or what else could it be?
PS.
Reset, restore did nothing, also tried removing the proximity.
Is dit een goede vraag?
Voeg een opmerking toe
4 Antwoorden
Het nuttigste antwoord
Power management IC no doubt. U2 Tristar Charging IC does not cause this.
Was dit antwoord nuttig?
Score 2
4 opmerkingen:
I have an iphone 5 with the same prob, so U2 of both phones busted?
door
It's not U2 it's PM IC.
door
If the main power ic is busted it won't even turn on right?
door
No because I have a iPhone 6 with this exact same issue which causes intermittent shut down issues (Already tried another battery).
door
Dit antwoord was oorspronkelijk aan een andere vraag gericht.
Before you go into the motherboard troubleshooting I would suggest that you charge the battery up to 100%, open up the phone, disconnect the charging port and proximity sensor and see if it still shuts off. If the problem is gone then re-connect the parts one by one until the problem re-occurs.
Score 1
3 opmerkingen:
Proximity already changed as it was broken, didn't solve the problem. I will try to unplug the charging port as well, thank you, will get back to you in about 9 hours.
Previously I'd thought that unplugging the proximity oughta fix it, it didn't, so I changed it, didn't fix it as well.
door
So far its still on, I'll see for a few days if it'll stay on like this, usually when batt gets around 70% it'll start turning off fast.
door
To be sure that it doesn't happen during this activity, open up a 10 hour long YouTube video and let it run for a while
door
My iPhone switches off when I lock it or when it’s go to sleep mode and for me to use it the screen must be on all the time please help
i would send it to the store you got it from and see if they can do anything about
Score -1
1 Opmerking:
Haha I got it back in 2013, in Tokyo, I'm currently in Jakarta
sad(T ^ T)
door
Voeg je antwoord toe
Anon545454 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 120
