Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Vragen Bekijk alle
iPhone 5s Turns Off by itself
So I have had this iPhone 5s since it first launched, and the batt died last August. Got a battery replacement mid December.
Problems:
1. The phone would mysteriously die when not in use. In 24 hours it'll for sure turn off by itself. Over night it'll shutoff. Keeping iPhone plugged in doesn't solve the problem, it'll still shutdown.
2. When around 20% batt left phone would shutoff, when plugged in will turn on again normally.
3. Changing to another batt didn't solve the problem. I bought like 5 replacement batteries, none of them fixed the problem, tried them on my other 5s as I have about 4 of them, worked perfectly fine, no random shutdowns.
Question:
Which ic chip is most probably busted? Main power IC or the U2 chip? Or is it something else??
PS.
In diagnostic there is Panic code
Update (03/07/2017)
@benjamen50
which one? the one @ the very right?
Is dit een goede vraag?
1 Opmerking
Wait a second what is the kernel panic code?
door
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
Power management IC no doubt. U2 Tristar Charging IC does not cause this.
Was dit antwoord nuttig?
Score 2
4 opmerkingen:
I have an iphone 5 with the same prob, so U2 of both phones busted?
door
It's not U2 it's PM IC.
door
If the main power ic is busted it won't even turn on right?
door
No because I have a iPhone 6 with this exact same issue which causes intermittent shut down issues (Already tried another battery).
door
Before you go into the motherboard troubleshooting I would suggest that you charge the battery up to 100%, open up the phone, disconnect the charging port and proximity sensor and see if it still shuts off. If the problem is gone then re-connect the parts one by one until the problem re-occurs.
Score 1
3 opmerkingen:
Proximity already changed as it was broken, didn't solve the problem. I will try to unplug the charging port as well, thank you, will get back to you in about 9 hours.
Previously I'd thought that unplugging the proximity oughta fix it, it didn't, so I changed it, didn't fix it as well.
door
So far its still on, I'll see for a few days if it'll stay on like this, usually when batt gets around 70% it'll start turning off fast.
door
To be sure that it doesn't happen during this activity, open up a 10 hour long YouTube video and let it run for a while
door
My iPhone switches off when I lock it or when it’s go to sleep mode and for me to use it the screen must be on all the time please help
Dit antwoord was oorspronkelijk aan een andere vraag gericht.
i would send it to the store you got it from and see if they can do anything about
Score -1
1 Opmerking:
Haha I got it back in 2013, in Tokyo, I'm currently in Jakarta
sad(T ^ T)
door
Voeg je antwoord toe
Anon545454 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 7,052
