How to fix 1907FPc 19" LCD Monitor feet from tucking?
it is stuck in the bothom
Is dit een goede vraag?
RENX , Check to see if there are removable plastic caps covering up screws that could be tightened to stop the screen from tilting. I had a stand that would keep tilting down on me and I wrapped a large an elastic around the hinged joint giving the problem and it worked. Good luck.
Was dit antwoord nuttig?
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 19
Altijd: 258
1 Opmerking
What is "tucking" and can you elaborate more on your problem
door Cameron
