Ga door naar hoofdinhoud
Guides for the Wi-Fi version of the iPad Mini 4—model A1538. Announced on September 9, 2015, the iPad Mini 4 is the successor to the iPad Mini 3.
Home button gasket compatability
IPAD mini 4. I can't find a direct replacement. Are there other MINI's that use the same gasket?
The entire assembly came apart when replacing the LCD / Digitizer.
What I have looks like a shim that was glued to the glass, followed by what looks like the rubber gasket.
If and when I find the part, does it reassemble as follows?
1) attach shim washer to glass
2) attach rubber to shim.
3)attach button to rubber.
4) glue down bracket.
I'm hoping if there is a replacement part it includes the shim and rubber as one.
Thank you.... Everyone!
Is dit een goede vraag?
3 opmerkingen
The IPAD AIR 2 is compatable and available from multiple sources.
door
tjmurf, Yes the link I provided says, Replacement for iPad Air 2 / iPad Mini 4 / iPad Pro and would be available at multiple sources.
http://www.unionrepair.com/?subcats=Y&pc...
door
tjmurf, I am wondering if you received a satisfactory solution. I have found a source of Home Button, Bridge, Rubber Gasket and Shim all in one packet.
However, I am at a loss as to the correct method of fitting the gasket and shim and can find no instructions on-line. Any new ideas?
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
tjmurf , Replacement gasket for IPAD mini 4 link below, verify correct for your model before placing order. 2nd and 3rd link may help in showing how button assy. Good luck.
https://www.youtube.com/watch?v=V0ViWDPB...
https://www.youtube.com/watch?v=6x1vBeCh...
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
tjmurf zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 6
Altijd: 584
