Ga door naar hoofdinhoud
The LG G4 was released in the US in early June 2015, as always focusing on high-end specifications and a refined fashion sense that makes it stand out in the premium smartphone market. Each version of the phone will have a different model number based on if it is sold by a carrier or unlocked (US or International). Some LG G4's are known to have bootloop problems.
Why is my screen doing this?
I broke my screen took the old one out, went to replace my glass. FAIL. busted it, ordered the bezel with the digitizer lcd and glass all in the frame already, clicked the ribbon cables into place power on my phone and this is what i have, and its progressively gotten worse
Screen flicker
Is dit een goede vraag?
1 Opmerking
@jch1993,James, That does not seam right that they will not exchange the screen, I do not know who you purchased from but perhaps try again and ask for a resolution manager and plea your case. Good luck.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
@jch1993 ,James, It is possible you have gotten a bad replacement screen. You may want to disassemble the phone one more time and check all your connections and board to make sure they are good and secure and undamaged. If you have not done already a factory reset link below, could also be done as it can some time's fix some pretty weird issues, although your will loose all your data. All looks good and reset did not work, probable bad screen assy. Good luck.
https://support.t-mobile.com/docs/DOC-28...
Was dit antwoord nuttig?
Score 3
1 Opmerking:
They are refusing to send me another screen aswell, only trying to refund me 50%
door
Voeg je antwoord toe
James Hill zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 123
