Ga door naar hoofdinhoud
Model A1051 / 4 of 6 GB harde schijf
90 Vragen Bekijk alle
What company of compact flash cards should I use?
Hey
I want to switch out the Harddrive of my ipod mini into a compact flash card.
I know that the cf card has to be fully ATA compatible and that sandisk works for this, but I am looking for a cheaper company.
Any suggestions??
Thanks
Is dit een goede vraag?
Score -1
1 Opmerking
I now used a 32GB card by transcend. This worked fine and only cost me $45.
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
As a photographer, I use Sandisk, however, Kingston and Lexar are widely known as well.
I would recommend Sandisk though as it is the most reliable.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Thanks, but mine has to be fully ATA compatible, because I will build it right in the ipod, and I dont know which companys provide this.
door
Actually each pin on a CF card corresponds with a pin in a IDE 2.5" HDD. So yes, every CF card is ATA compatible. If it works in a dSLR, it is ATA compatible.
door
Voeg je antwoord toe
Kana zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 6,114
