Ga door naar hoofdinhoud
A digital camera designed and manufactured by Sony in 2012. A 18.2 megapixel camera with Wi-Fi, GPS, and a memory card slot.
15 Vragen Bekijk alle
How to do a factory reset?
I've gone thru all the options on the Sony eSupport pages, it's a no go.
The power lite goes on, but nothing else works. The lil red "access lamp" (#25 in the manual, next to the sd card) flashes 2x then off, which may be an error code? The power lite goes off only if I remove the battery.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
@paulieh01 this should work to reset your camera:
"The lil red "access lamp" (#25 in the manual, next to the sd card) flashes 2x then off" is an indicator for the memory card. You may have some problems with the card. Remove and/or replace it it and see if that changes anything.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Paulie zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 2,096
