Ga door naar hoofdinhoud
The Saturn Relay was the first and only minivan from the Saturn brand of American automaker General Motors and was built alongside its sisters, the Buick Terraza, the Chevrolet Uplander, and the Pontiac Montana SV6.
29 Vragen Bekijk alle
Keyless Remote Entry Fob battery replacement on 2005 Saturn Relay?
The battery is very low in our car's keyless remote and needs to be replaced, but there are no screws in the back or any way to access a battery compartment. The dealer said that we'd have to order a new remote, at the cost of nearly $100. A few places online offer a replacement remote, but the cheapest is around $65, and they say you still have to pay the dealer a programming fee to get it to work with your car. How big a scam is this, when a $5 battery replacement would do the trick?!
Any ideas about how to get it open?
Thanks for any help!
Is dit een goede vraag?
Score 1
1 Opmerking
I have a 2005 relay. The dealer said the new fob that I purchased cannot hold the programming. He said it would cost $75.00 to diagnose the reason why. Does anyone have any ideas as to why it won't hold the programming so I could save myself $75.00 plus whatever the fee would be to repair the possible issue?
Thank you
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Battery replacement is (one of these:CR-2032,CR-2016 OR CR-2025 batteries) found at most big box stores. Use a coin to open the remote from the bottom of it. Please see owners manual (link below) If you do get a new key fob remote. You will have to get it programmed by a GM dealership. Battery size is not specified in the Owners manual, you must open the remote to determine which battery to get.
Battery Replacement
Under normal use, the battery in your remote keyless
entry transmitter should last about three years.
You can tell the battery is weak if the transmitter will not
work at the normal range in any location. If you have
to get close to your vehicle before the transmitter works,
it is probably time to change the battery.
Notice: When replacing the battery, use care not to
touch any of the circuitry. Static from your body
transferred to these surfaces may damage the
transmitter.
1. Insert a flat object, such as a coin, into the slot on
the side of the transmitter and twist it to separate
the halves.
2. Gently pry the battery out of the transmitter. Do not
use the metal flanges to pop out the battery.
3. Replace the battery.
4. Reassemble the transmitter. Make sure the halves
are snapped together tightly so water will not get in.
5. Press and hold the lock and unlock buttons
for seven seconds to synchronize the transmitter.
6. Check the transmitter operation.
Source: Page 93 of owners manual. Section 2 - 7
Here is a link to your owners manual.
http://www.saturn.com/assets/en/pdf/owne...
Was dit antwoord nuttig?
Score 3
1 Opmerking:
Excellent answer +
door
Voeg je antwoord toe
timsteinwachs zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 13
Altijd: 10,045
