Ga door naar hoofdinhoud
The Canon Pixma MP480 is an all-in-one color inkjet photo printer released in 2008.
21 Vragen Bekijk alle
How to reset page counter for ink absorber full (error 5B00)?
I have been trying everything I can find on google and youtube (short of downloading a sketchy exe file), but I can't reset the page counter. I already cleaned out the ink absorber pads, but my printer won't print until this has been reset. I hate planned obsolescence.
Is dit een goede vraag?
Score 65
19 opmerkingen
i have a 5B00 error and let me know how to approach it
door
Last week I had a similar іѕѕuе, I couldn’t reset the page counter on my Canon Pixma printer.
I tried everything and nothing helped.
Finally I managed tо fix this error after getting help from Cannon Windows Support
Follow the steps here: http://bit.ly/Error5B00
It should solve the issue
Goodluck
door
There are various reset methods for different Canon printers. None allow resetting of the 'ink pad full' on the MG2550S, thought you may get limited access to other features like 'nozzle check'. Even physically transfering the eeprom to an eeprom reader/writer doesn't help unless you know what parameters to change.
door
hie guys, i have got canon TS5040 , it is reflecting error 5b00 wat can i do,,
door
14 commentaren meer tonen
Voeg een opmerking toe
6 Antwoorden
Gekozen oplossing
Hi,
Have you tried the following:
1. Press and hold the power button
2. Whilst holding the power button operated, plug the power cord back into the printer.
3. Keep holding the power button until the printer begins to reset itself and come online, then release the button.
4. Wait for the green power light to turn off, then press and release the power button again.
It should blink for 2-3 seconds and then stay on.
Hopefully the printer has been reset and is ready to print again.
Was dit antwoord nuttig?
Score 22
14 opmerkingen:
No, this didn't work. When I plug in the printer while holding the power button, the green light comes on, but nothing else happens. When I release the power button, the light goes off again and the printer does not come on without having reset anything.
door
Hi, @lynanne ,
Just for my information, did you also try the procedure as shown in the link?
door
this didn't work for me either and the link doesnt work
door
Hi, please suggest an answer for my Canon e470
door
These are throw away printers. Remember that. Once that ink absorber error comes up thats it. Time for the dumpster.
door
9 commentaren meer tonen
I had the same issue and solved it this way.
  1. Press and hold the power button (While connected to power)
  2. Press the ‘cancel’ button SIX (6) TIMES
  3. Release all buttons
  4. Press ‘cancel’ button FIVE (5) Times
  5. Press the POWER button ONCE. (It should print a reset information page)
  6. Press the power button to turn off the printer then turn on again.
  7. This worked for me.
Score 17
16 opmerkingen:
Hi Simion,
Could you please help me to reset Canon Pixma G4000 printer. I've tried your guidelines but nothing happened.
door
thanks a lot
door
its worked with me but different first step
power off the printer
hold cancel first then hold power , then release cancel and keep on power then press 6 times on cancel
Release all buttons
canon G3400
door
This has worked out marvelously, i was so worried about taking back my Canon Pixma G3411 back to the vendor but was able to sort out the issue locally using this guide. Thank you for the help Sir
door
Dear Sir,
Could you please help me to reset Canon Pixma G2400 printer. I have tried your guidelines but nothing happened.
door
11 commentaren meer tonen
My Canon G2000 printer has a 5b00 error and I have found this software, it fixed the 5B00 error on my printer, advise you to try it out - http://resetkey.net/reset-canon-g2000-co...
First: You have to put printer into SERVICE MODE
  • Turn off Canon G2000 printer
  • Press and hold Canon G2000 printer’s RESET button
  • Press and hold printer’s POWER button.
  • Released Canon G2000 printer’s RESET button, POWER still pressed
  • Press and released Canon G2000 printer’s RESET button 5 times
  • Released Canon G2000 printer’s POWER button:
  • Now, Canon G2000 printer on SERVICE MODE condition. In this condition, computer detect found new hardware.
  • When operating system detect FOUND NEW HARDWARE, wait about 20 seconds and press CANCEL
Second: Download Wicreset or iWic to reset Canon G2000 waste ink counter.
Score 16
5 opmerkingen:
Please give a solution of this problem for Canon e470.
door
Thank you very much! Reset my Canon 3000 in a minute. Easy. Had looked around at buying a new printer but really had no time for that anyway, i try your link and It works
door
Thank you pro, it works!
door
Hi I need Help My Canon G4100 came with 5B00 issue now with this Lockdown no where to take it to fix Pls HELP Tks
door
Great help, thank you very much!
door
hi you can try the service tool here….
https://truee2.blogspot.com/2020/05/how-...
Score 1
3 opmerkingen:
Indeed, this solution worked flawlessly. Thanks a lot!
door
You do not even need the tool on some models. See, for example: https://www.youtube.com/watch?v=Zu_vONAE...
door
This worked amazingly for me as well. I couldn't get it to reset the manual way no matter how hard I tried. Using this software, I was able to fix the problem in 5 minutes.
door
It means its time for a new printer. Dont waste your time trying to reset the ink absorb counter. It wont work.
3 opmerkingen:
The trick mentioned just before yours work. There is nothing constructive about telling to change a printer that can be easily fixed...
door
Catherine Desrochers speaks the truth. Here, for example, is how to reset the counter on a G3200: https://www.youtube.com/watch?v=Zu_vONAE...
door
You can’t reset this code. It means it time to buy a new printer. I wouldn’t lie to you. Its almost impossible to re-set the ink absorber counter.
door
Hi could you plz help me my printer is canon Ts6120 code error 5B00
1 Opmerking:
Its almost impossible to re-set the ink absorber counter. It means its time to buy a new printer. Trust me on this.
door
Voeg je antwoord toe
LynAnne zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 42
Afgelopen 7 dagen: 284
Afgelopen 30 dagen: 1,132
Altijd: 264,457
