Ga door naar hoofdinhoud
Released on October 23, 2012. Core i5 or Core i7 Processor. Apple Fusion Drive.
208 Vragen Bekijk alle
Where does this spring belong
I found a spring after removing the fan for my late 2012 Mac mini. The only springs I could find online pertains only to the ones for the heat sink. I did not nor have I ever removed/replaced the heat sink of my MM. So where did the spring come from?
Another question is why doesn't the screw for the fan/cowling come off? It comes off the motherboard fine but it's stuck holding the cowling and fan together? Thanks.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
One the first picture of the fan, showing the black screw. The spring goes in under the screw (i.e. The screw goes threw the middle of the spring) to create tension and push the fan down. Hope that helps!!
Was dit antwoord nuttig?
Score 3
1 Opmerking:
Thank you. Does it go in between the heat sink and cowling or in between the heat sink and the logic board?
door
Voeg je antwoord toe
Rodney B Ungwiluk zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 409
