Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De Dell Inspiron 500m, uitgebracht in 2003, is een lichtgewicht laptop die is gebouwd voor draagbaarheid en alledaagse prestaties. Leer op deze pagina hoe u het apparaat kunt repareren en onderhouden.
Hinge repair or replacement,screen works
Hinge repair or replacement of Dell 500 laptop.Screen is working
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
Hi,
Here is a link to the service manual for your laptop.
http://downloads.dell.com/manuals/all-pr...
It details the necessary pre-requisites and the procedure how to remove the display (click on Display Assembly in contents section), so as to gain access to the hinges.
The hinges are available online. Here are a couple of examples. It is not a recommendation to use either of the sellers. It is just shown to give an idea of what is on offer and the cost. Just search for Dell Inspiron 500m hinge to get results that may suit you better.
http://www.techeeze.com/estore/products/...
http://www.ebay.com/itm/New-Genuine-Dell...
Hopefully this is of some help.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
The model of my laptop is a Dell 500.Maybe you can provide me with the website of this specific laptop.Will be very grateful.
door Deel
Hi,
You confused me because you have written Dell Inspiron 500m in the Choose a Device option box of your question and just Dell 500 in the actual question area. (click Options link at the top of the page near your question to see what is written. This information then is passed to the image tag to the right of your question at the top of the page) That is why I responded with the one I did.
Anyway here is a link to the service manual for a Dell 500
https://www.manualslib.com/manual/553401...
Here is a link to one supplier.
http://www.pchub.com/uph/laptop/291-5890...
door Deel
Voeg je antwoord toe
ivandermerwe18 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 27
Altijd: 487
