17% only changing in my phone
My phone will be having 17% charging only, why ?
Is dit een goede vraag?
@pachadan , Subeesh , Check charge port for dust/lint/debri, blow out the charge port/clean with canned compressed air or clean with small soft paint brush. Wiggle the connection a little to see if charge port is loose and not connecting. Try another compatible charger/cable and see if it charges better.
Read through a few forums and this was suggested solution.
1. Remove your battery once and fit it back.
2. Plug you charger cable from adapter to phone. Guys Iam not sure about usb cable users.
3. Press the power button for more than 5 to 10 seconds. You will get a battery icon but the charge will not show as it charging.
5. Don't leave the power button immediately.
6. Hold it continuously for 3 to 4 mins. The battery icon will flicker till that point.
7. After this the boot logo will come. Once it comes, your mobile will start charging.
Check the links below for more info. and trouble shooting your charging issue. It may be a faulty battery and time to replace or a hard/factory reset 3rd link below. Good luck.
http://gadgetstouse.com/featured/solve-s...
Was dit antwoord nuttig?
@pachadan The major reason for slow charging is that we leave the phones for charging for long hours than required. So if you tend to leave your phones for charging overnight, you might start avoiding it.
These are few mistakes that you should avoid when charging your phones:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 94
