Ga door naar hoofdinhoud
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Vragen Bekijk alle
iPhone 3GS charges up to 1% and instantly dies, boots repeatedly
So I recently bought a new battery for my iPhone 3GS claiming to be a 1600 mah battery. However, when I installed it into my phone it was stuck at 69% so I tried to charge it to 100% to calibrate the battery. But it stayed at 69% I played a 10 hour long video till it finally died (oddly enough still saying 69%). So I charged it again but it was at 1% with the little outlet logo instead of the lighting bolt logo. And then it died again tried turning on by booting showed 1% and died. I have recently removed an ifixit battery that it previously had that expanded I don't know if it could have damaged the phone in any way. And the last time I checked it, it said 100%. But as soon as I unplugged it, it died. What is going on with the phone?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
There is a "gas gauge" in the battery that communicates the battery charge level to the phone. If it is defective, then it will cause all kinds of problems.
Chances are you have a bad battery. Can you have it replaced by the supplier?
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
alexandercisneros2 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 75
