Ga door naar hoofdinhoud
The HTC HD2 is a smartphone manufactured by HTC and running the Windows Mobile 6.5 operating system.
13 Vragen Bekijk alle
installation guide of the motherboard?
Hello and congratulations for the site ....
My problem is that HD2 is no longer able to start some time.
by the various attempts I made with technical, it appears that the problem is the motherboard.
If you can put a guide on how to mount it and maybe buy it from you.
Thanks and good luck!
Is dit een goede vraag?
Score 2
2 opmerkingen
Is this item water damaged at all?
I will be making a tear down guide soon.
door
The motherboard will be too expensive to purchase. You can find a working HD2 with a cracked screen or broken LCD and buy it and use the board from it.
If you have insurance through the carrier, pay the $135 and get a replacement phone. (It's $135 for T-Mobile).
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
If you are interested in checking out the teardown and to replace your motherboard, here are the guides that i use. http://forum.xda-developers.com/showthre... and http://pocketnow.com/hardware-1/official... good luck
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Michele zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 6
Altijd: 8,591
