Ga door naar hoofdinhoud
Sneeuwmobielen zijn gemotoriseerde voertuigen ontworpen voor reizen en recreatie in de winter op sneeuw. De motor drijft over het algemeen een continue rupsband aan de achterzijde aan die het voertuig voortstuwt, terwijl twee ski's aan de voorzijde zorgen voor sturing.
Why is my snowmobile bogging
I have a1999 Polaris 600 xlt and I was running about 55 mph when I released of the gas and my sled lost a little power and was bogging out I lifted the hood and oil cap was off and there was oil in my air filter so I wiped all the oil up and it seem a little better buts still boggs out .I also changed the spark plug ran it a bit then my air filter blew a flame through it the sled drives just doesn't feel 100% what could be the problem
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
@lanny3 , Lanny, How well did you clean the oil in the filter box, did you replace the oil drenched filter as it could be clogged choking the engine, also make sure the clutch and belt are clean of the oil. There are a few things that could cause your engine to bog. Bad fuel, fuel line collapsing(pinched), clogged fuel filter,dirty carburetor, fuel pump failing, Carbs out of adjustment, bad plug wire, wires/plugs shorting out/loosing connection, weak coil/ignition box/CDI, wrong/fouled plug, vacuum leaks/bad crank seal, stick valve/reed, etc. I will post a link below to the service manual which may aid in your diagnosing and repair and a 2nd link to a forum diagnosing your issue. Good luck.
http://coodie.com/polaris/1999-Polaris-S...
http://www.snowest.com/forum/archive/ind...
Was dit antwoord nuttig?
Score 3
1 Opmerking:
Ohm out spark plug caps (should be 4-5k ohms),pull a fuel sample let it sit for a couple hours & see if /or how much water there is in the fuel. Secondary clutch may have a broken button or the clutches all together may be dirty......There can be many seen and some not yet seen issues when it comes to troubleshooting snowmobiles I just threw out a couple for you -if they help at all.?
door
I totally agree with L Pfaff comment on problem-solving but I want to ask you one thing: how long have you changed the tracks of your snowmobile? If it's a long time ago, then you should probably change them to new ones, for example from the compositsnowmobiletracks company. I have been using them for several years and am generally satisfied.
My 750 touring Arctic Cat skidoo starts fine with choke...holds an idle well.After driving for extended time skidoo wont idle on its own when I stop. She just cuts out when I release the throttle. When I go to starter up again tbere is a clanging sound and I have to turn her over several times before it catches. When she starts up she won't idle on her own.. Shuts off as soon as I release throttle. I have replaced all the gas..added new gas with gas line antifreeze and fuel injection fluid. Also use seafoam to help clean carburetor. Put in new spark plugs and new battery.
Voeg je antwoord toe
Lanny zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 39
Altijd: 5,515
