Ga door naar hoofdinhoud
The LG G Pad 8.3 is a tablet created by LG Electronics Inc. that weighs 11 ounces, has 16 GB of storage, and has a 8.3 inch screen.
20 Vragen Bekijk alle
Got new battery for lg vk810 let it go dead
I got a new battery for lg 8.3 vk810 accidentally I let it completely die now I can't get it to charge or turn on I tried the 20second thing but it still won't do. anything. Also my screen is very dim?
Is dit een goede vraag?
5 opmerkingen
lisasaunders528 "still won't do. anything. Also my screen is very dim?" so it does come on but has a very dim screen? Clarify this for us. A dead battery would not give you anything.
door
I replaced the battery and was working fine for a couple of days but then accidentally. Let it die now I can get it to charge or turn on
door
Sounds like you are having an issue with either your charging cable, your charger, or the charging port. Have you tried a different charger/cable?
door
Yes I've tried different cable and charger box it will sometimes show me the LG screen but can't get it to go past that I just ordered a new charger Port with flex cable so I hope it's the problem.
door
Also every once in a while I get a faded ring around the outside of the screen does that have anything to do with it or is that a hole new problem itself?
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Got the new flex cable in and its working great thank you for your help
Was dit antwoord nuttig?
Score 1
Het nuttigste antwoord
Try disconnecting the battery for a few minutes then replace battery and before turning it on plug it in and let it charge . Leave it plugged in for a day. see if this helps
just in case you need a guide
LG G Pad 8.3 Battery Replacement
Score 2
3 opmerkingen:
It's a new battery I just replaced it. And I let it charge over night
door
disconnect it then reconnect it before recharging . Connection may not have seated correctly . Check connection for dirt or lint
door
Installed. New flex cable and port and is working great now thank you
door
Voeg je antwoord toe
lisasaunders528 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 2,224
