Ga door naar hoofdinhoud
Released July 24, 2014, Amazon's Fire Phone is Amazon's first smartphone, designed to compete with iOS, Android, and Windows Phone devices.
39 Vragen Bekijk alle
Wifi signal weak after battery change
After replacing battery in amazon fire phone, I was unable to connect to wifi weak signal. it pick up signal only within 1 foot from router range. And also not full signal..
any suggestion what I did wrong during battery replacement process.
Is dit een goede vraag?
Score 2
4 opmerkingen
This is just a guess after looking at the tear down on Ifixit. I would be looking at the flat antenna connections and making sure they didn't come loose. It looks like you could easily catch the antenna cable with the adhesive strip you pull out from under the battery.
door
you are talkin about the black strip cable...
door
I have this problem too. Can anyone solve it for me?
door
I check all the strips also antenna cable which is perfect, not loose but facing same problem very weak signal of wifi and Bluetooth this all due to replacing my fire phone battery.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi,
Here is a link to the Ifixit teardown for your phone.
In Step 7. of the teardown it mentions flat antenna cables, just after removing the battery. Perhaps you loosened their connections when you removed the battery.
Amazon Fire Phone Teardown
Hopefully this is of some help.
Update (02/03/2017)
Hi,
Here is an image showing the actual connectors. Check that they are both OK.
(Click on image to enlarge for better viewing)
Was dit antwoord nuttig?
Score 5
19 opmerkingen:
Haha. I was just commenting about the antenna cables. I must have clicked on the question just before you answered, and my screen hadn't refreshed.
door
or the golden strip you are talking about
door
Hi, It may be both as it mentions cables (more than one)
door
I checked it all the way.. black strip and golden strip are tightly inserted...
door
again tighten the black trip...but no success. wifi signal bar some time flicker..and jump to full signal but all sudden drop.
door
14 commentaren meer tonen
Voeg je antwoord toe
Khurram Shahzad zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 14
Altijd: 3,029
