Ga door naar hoofdinhoud
Model number NX785QC8G, released in 2014. RK3188 Quad core ARM Cortex A9/1.6GHz Processor, 1GB DDR RAM.
help me I need help
my screen wont turn on anymore how can i get it to turn on
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
@killerclownson ,nathan eastman , Make sure your device is charging or fully charged, try a different charger or cable if not sure it is charged or charging. You can try and hold the power button and volume down switch, a android logo should appear, then go into menu and select boot normally. Below are links that also help in getting your device to power up. Good luck.
http://www.tomsguide.com/forum/id-207915...
https://www.quora.com/How-do-you-reset-a...
Was dit antwoord nuttig?
Score 3
1 Opmerking:
it might work i have problems
door
Voeg je antwoord toe
nathan eastman zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 17
Altijd: 123
