Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
Slow charging or Normal
My IPhone charges 0-100% in 4 hours
The current temperature is 4 degrees here
But when I make my iPhone a little hot it charges fast
Should I try once blow dryer to fix or what??
Is dit een goede vraag?
Score 1
1 Opmerking
sir dont do any heating you proper charger .... or change your lighting connector and adaptor
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Shahid Akbar,
it's normal chemical reaction of the battery in -4C to 5 C. nothing to be worried about. :-) basic physics
Was dit antwoord nuttig?
Score 2
Hi
- are you charging via computer or via wall socket?
- are you using the standard official charger that ships with the iPhone?
An Apple lithium-ion battery uses fast charging to quickly reach 80% of its capacity, then switches to slower trickle charging. So typically, a 0%-100% should take you around 3 hours, give or take.
Some tips to achieve faster charging:
- Use a wall socket
- Use an iPad charger (It's rated at higher amperage)
- Switch on Airplane mode while charging (charging time cuts down to almost half!)
Hope it Works
Thanks
Varun
Score 1
Voeg je antwoord toe
Shahid Akbar zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 257
