Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
How to adjust flex antenna because I have no wifi or bluetooth?
The wifi was not working neither is my bluetooth. I looked it up and someone said i need to adjust my flex antenna, does anyone know if this is true and if so does anyone have a guide to fix it?
Update (01/28/2017)
Ok she dropped the phone and now the wifi does work but only when she is within 10-15 ft of the wifi base
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hmm...
There's nothing to "adjust" on the antenna. You will want to look to see if the antenna is properly connected to the logic board and housing. Keep in mind that there are several antenna elements in the phone, including the housing. I would use this guide to dis-assemble the device. Read through it first and focus on the antenna elements.
There is also a possibility that you have a logic board issue...you don't really say what happened to the phone prior to the issue. Was it dropped, water damaged, prior repair etc. ?
Was dit antwoord nuttig?
Score 1
1 Opmerking:
door
Voeg je antwoord toe
Nick Genco zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 137
