Ga door naar hoofdinhoud
Laptop use to power on automatically when I raised the lid.
I just purchased this laptop a week ago. I charged it up. And when I raised the lid, it immediately came on . It came on just like I had hit the power button. And I like that. But now a week later it doesn't do that. When you shut it down ( not using the power button) thru windows, it shuts down. But when I lift the lid, nothing happens. You now have to hit the power button. I would like it the original way. Has anyone had this before. And I dont drink and I am not imagining it. Plz help.
Is dit een goede vraag?
Score 2
2 opmerkingen
Hi, Check the advanced power options settings in Control panel > Power Options especially in regards to lid functions whether to hibernate or sleep etc.
door
everything is in sleep mode and the fast mode is checked also
door
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
well, I found the fix. Its a Samsung and when I got the latest Samsung update, it changed a setting. It changed the "AUTO BOOT" in the Samsung settings to off. Turned in on and its working again. Thanks for the suggestions everyone.
Was dit antwoord nuttig?
Het nuttigste antwoord
When you shut it down with Windows, the machine powers off completely. You must turn turn it back on using the power button. When you close the lid while it's still powered on, it will go into sleep mode, which allows it to notice when you open the lid. A simple solution: close the lid and don't shut it down.
Score 2
Darrell: I have the same issue and don't see a setting depicted as AUTO BOOT. I was looking in the Power settings. Can you let me know where that setting is? Thanks, Jim
Update (01/29/2017)
It worked. Thanks. I looked three times in the Power settings, thinking that I was missing something obvious. Again, thank you. It works now. Jim
Either look down in your taskbar for the Samsung Settings icon or on the bottom left "Windows" click it, scroll down until you find "Samsung" (it should have a arrow with a drop down), drop down and go into Samsung Settings. The first window that opens should have a on/off button that is for AUTO BOOT, just turn it on by sliding it over. Good luck and let me know.
Voeg je antwoord toe
Darrell Patterson zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 28
Afgelopen 30 dagen: 140
Altijd: 21,277
