Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
Microsoldering iPhone 6 Plus touch ic
rework station nozzles:
im looking for angled 6m nozzles for my rework station, I can't find them anywhere! Can you help?
Also I'm struggling with my tweezers, I've been chasing tiny fuses and caps around with a syringe needle as I can't find anything small enough!
What tweezers do you recommend?
Many thanks
Simon
Is dit een goede vraag?
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
A lot of times I use an xacto knife. Those little cutting knives with a small blade
Was dit antwoord nuttig?
Score 2
what rework station do you have?
I recommend any cheap tweezers you can find or check out Louis Rossman's recommendations on any of his youtube videos.
I personally use tweezers that came with a cheap soldering kit I bought, they are ESD safe and about the same size as the ones you can get in the ifixit store. Buy more than one set of tweezers as they do not like heat and will probably warp the tips the first time they are used. Also if you are chasing the components you may want to cautiously turn down the air flow on your station and up the heat. I am waiting to make a little more money until I invest in Hanko hot tweezers. They seem to be the best for working caps and filters on small boards. As far as the nozzle goes I use the smallest one that came with my rework station Kohree 110V LED Digital 858D SMD Hot Air Rework Station Solder Blower Heat Gun. It has done well for me so far.
tweezer = dumont 0203-0-P0. They bend easily so you have to be careful with them, but they are the finest tips you can find. Nozzles are available on ebay.
2 opmerkingen:
Interesting...
Have you tried 72700-D? According to spec they are even finer (0.01 x 0.05 mm). At what point do they become too fine?
I use the 5-SA from CHP (Hakko) and they are very fine point but more importantly they are only 5$ each. They're good down to 0201 but a little big for 01005.
https://www.hakkousa.com/products/chp-to...
door
I had not seen those, but that seems excessively small to me. I would think it would be very difficult to not bend them. I do use 5-sa as a general use tweezer but I keep 1 set of 0203-0-po for handling 01005. I do not use them for anything else.
door
Voeg je antwoord toe
simonkcook zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 279
