Ga door naar hoofdinhoud
Repair guides and support for gas, electric, and human powered machines used to cut grass, whether self-propelled or “walk-behind.”
cord pull back.when pull to start
i have a lawn mower, when i pull the cord it pulls my hand back
Is dit een goede vraag?
Score 2
1 Opmerking
I have pull back and also after a new flywheel key was inserted
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
This type of kick back is usually caused from the engine timing being off.It is usually a sign of a bent or sheared key between the flywheel and the crankshaft. Remove the upper cover of the engine. Remove the starter cup from the top of the flywheel. Remove the nut on top of the flywheel and check the alignment of the groove in the flywheel with the groove in the crankshaft. If these grooves are not perfectly aligned, the key is bent or sheared. Remove the flywheel to replace the key. But make sure that you follow the directions for your mower, I just gave some general ones. Hope this helps. Good luck
Was dit antwoord nuttig?
Score 3
1 Opmerking:
My mower exactly has the same issue and the problem is at "key" (made by soft metal) broken into 2 pieces and groves on both crankshaft and fly-where are shifted about 20+ degree. the engine turns revers is because when the compressed gas-air explored before piston reached to the top so explored gas-air push piston to cause engine turn revers.
door
when you order key, you may order flywheel puller
Mine does the same when you pull it but the key way is in tacked and not broke can someone help
2 opmerkingen:
:Looks like this is common problem with no easy solutions. can the key be made to fit the groove tightly and solve the problem. In my case, a new key did not solve the problem. I have had the problem for many years. when it was new?
door
tap it with a hammer carfully checking frequently just so it will fit firmly in the grooves.
door
Voeg je antwoord toe
george zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 40
Altijd: 21,786
