Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
Displays Screen turns to stripes after a while
I have changed my iPhone Display. If I click on the power button, the screen is just normal without any errors. After 1-2 seconds, it turns to an error screen with many (mostly) white stripes from top to bottom. I have tried to plug the connectors again and again, still same issue.
Any ideas?
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Its LCD Issue Replace The New Screen & Check
Hope it Works
Thanks
Varun
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Indeed, the screen was broken.
door
Het nuttigste antwoord
Could be a damaged cable. But it sounds more like you just aren't seating the connections to the digitizer properly
Here's a guide
iPhone 5s scherm vervangen
Here's parts in case that's the issue
iPhone 5s LCD and Digitizer
Replace a front glass digitizer panel or malfunctioning 4 inch IPS LCD display compatible with the iPhone 5s. Features a 640 x 1136 pixel Resolution. Afbeelding
Product
$39.99
Score 3
I think that it might be touch disease
2 opmerkingen:
So you think the Display is broken?
door
No the IC that controls the display and digitizer
door
Voeg je antwoord toe
whatsmyname zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 157
