Ga door naar hoofdinhoud
Reparatiehandleidingen en ondersteuning voor auto's en vrachtwagens geproduceerd door de Toyota Motor Corporation.
How do I replace tail light assembly
How do I replace the left rear tail light assembly on my 2007 Toyota Highlander
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
@kemisi ,Kerry Simms remove the small interior trim cover opposite of taillight being remove, unplug harness and remove the 2 nuts holding taillight, pop out tail light. Reverse procedure for install. The 1st link shows how to access taillight to enable you to gain access to the mounting bolt/nuts. The second link shows you a clear pic. of the tailight and mounting bolts that nuts must be removed from to remove taillight.The The links below will aid in the removal process. Good luck.
https://www.carcarekiosk.com/video/2002_...
http://www.ebay.com/itm/06-07-TOYOTA-HIG...
Was dit antwoord nuttig?
Score 4
3 opmerkingen:
Unfortunately my highlander is an 07, the answer given was for 08 +, thanks for the try!
door
@kemisi, Kerry Simms, UPDATED, Use the written instructions and the video link in my original answer and you should not have a problem removing taillight. I also posted a link to what the taillight looks like from the back side showing the 2 mounting studs, just click through the different views below the pic. If not comfortable doing this, take into a good shop and have a technician do it for you, approx 1/2 hour labor charge.
door
First link is worthless, it simply takes you to an advertisement for lightbulbs. It doesn't show you how to remove a tail light assembly, something required if you are attempting to change out a side marker bulb. Second link is also worthless, it just takes you to ebay listing of tailight assemblies.
door
Voeg je antwoord toe
Kerry Simms zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 41
Altijd: 11,525
