Ga door naar hoofdinhoud
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
548 Vragen Bekijk alle
Logic board or Psu?
I have a mid 2007 intel iMac 20" that won't power on. When I plug the ac adapter in the first led comes on. When I press the power button led's 2 and 3 come on and the fan spins at regular speed and the optical drive starts up. Led 4 never comes on so I think its an LCD or video card problem. Do I need to test the Psu or is it the logic board or the video card? Thanks in advance!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Try plugging in an external monitor, it could be the inverter... if nothing shows up, its the logic board. It would be unlikely that the problem is the PSU as your computer does start up and shows LEDs (which means it can process.. to an extent)
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
If I hook the external monitor through mini-dvi, will the iMac automatically recognize the external monitor when it boots? Thanks for your reply!
door
If the LCD or the inverter is broken, the monitor should work, if it doesn't work, that means its the logic board thats shot (most likely)
door
Voeg je antwoord toe
Jonathan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 1,230
