Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Deze variant, die tegelijk met het AirPort Extreme-basisstation werd uitgebracht, is uitgerust met een harde schijf en biedt 802.11ac-snelheden op een Time Capsule NAS.
Time Capsule not powering on
I've been using this device for about 1 year until one day I found the light blinking amber. The Airport app was reporting the device was overheated. I pulled the plug and waited for it to cool down and when I plugged it back in there was no light at all. All I could hear was the noise of HDD spin up and nothing seemed to work.
It's out of warranty so can't take it to apple.
I cracked it open and found out that the PSU seemed to be functional. I checked the output voltage and it was a solid 12 Volts. But the fan doesn't run at all. I even tried to apply voltage to the fan to see if it runs but it didn't.
I checked the fan socket on the mainboard and 12 Volts appeared on the multi-meter.
Can I be sure that the fan is faulty? Because I don't want waste money on a PSU to find out it was not necessary.
BTW can someone verify that a working TC acts like mine when no fan is connected.
Thank you
Is dit een goede vraag?
Score 3
10 opmerkingen
@shoeib hey bro, did you find a solution?
door
@ironjer - I'm sure a new fan fixed the cooling issue
door
@jesus no man. I eventually came to the conclusion that the logic board is fried.
door
@shoeib maybe a bake... mine TC no fan spinning and no front light either but, the hard disk power on. I don't want waste money in new PS. :(
door
@danj I have no front light and no fan spinning, just the HDD works. Maybe the Logic Board is failing...
door
5 commentaren meer tonen
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Gekozen oplossing
More likely the fan died here. For about $20 US you should be able to find one.
I don't have a A1470 TC right now but I've had to replace quite a few fan units across the entire line of TC's
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
Do you by any chance remember how the TC acts with a faulty fan?
Thank you
door
@danj would TG Pro read this?
door
@mayer - TG Pro won't work here. It only works under OS-X or MacOS. The TC's use a custom file system and its own OS. AirPort Utility will report if the unit is overheating.
door
See if any of the following articles can help:
Score 1
Voeg je antwoord toe
shoeib zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 28
Altijd: 3,534
