Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Reparatie-informatie en handleidingen voor het uit elkaar halen van snelkookpannen.
Opening pressure cooker to replace LED board? How?
I need to replace the LED PCBoard on my electric pressure cooker as the LED display is broken. I managed to get the spare part from an appliance spares place, but now I have no idea where to open the Pressure cooker (easiest way), to swop out the old board for the new one. PLEASE HELP :-) - Cuisinart Electric Pressure Cooker CPC-600 or AEG/Electrolux EPC600.
Is dit een goede vraag?
Score 2
2 opmerkingen
Where did you get the LED board?
Thanks!
door
why my presiure cooker have so load terrible sound when turn
door
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Gekozen oplossing
I just can't find any teardowns or repair guides on this. These people sell the parts and have a toll free number and may be able to assist you: http://www.ereplacementparts.com/cuisina...
Was dit antwoord nuttig?
Score 2
You have to undo all the screws from inside and slide the outer case off there is a screw underneath a label and the front panel peel off label there should be to screw underneath at the top when you have done that there are 4 screws holding the panel on for the led circuit board I have done one my self so please put all the screws in a safe place as I did so you don't lose them I hope this helps you
2 opmerkingen:
I hope this helps you out
door
where can you get the led display Pressure king pro 5l
door
Voeg je antwoord toe
Phillip zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 41
Altijd: 3,997
