Ga door naar hoofdinhoud
Disc not spinning/No Disc error
Trying to fix this DVD player - the owner said it doesn't read discs. On investigating I found that it wasn't spinning discs at all. I've replaced the laser/motor unit but it's still the same. The disc starts moving 2 or 3 times very slowly but then it gives up and says no disc. Both laser/motor units do exactly the same.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Hi,
Here is a link to the service manual for your HTS. Apologies if you already have it.
Scroll to p.30 to see how to test the DVD section.
http://elektrotanya.com/sony_hc-dz830w_d...
To download the file when the sentence below the Document preview box changes from This file is downloadable free of charge: ...processing... to This file is downloadable free of charge: Get Manual, click on the Get Manual as this is the download link. Be patient, it takes a little while to find the file.
Hopefully this is of some help.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Thanks for this...I hadn't already got it. I will play around with the service menus and see if I can get it to do anything and report back
door
Hi,
Just a quick thought.
Are the lasers turning on? Watch your eyes!!
Disc starting to move indicates perhaps that it is looking for the file "start" location on the disc but if it cannot "see" it or any other data because the laser is not being switched on, it stops.
door
They say this one provides them with some clues.
https://www.winxdvd.com/troubleshoot-dvd...
Voeg je antwoord toe
phonesurgeon zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 6
Altijd: 12,699
